Throttle body
DannyC
Throttle body
Post by DannyC »
What is the stock size of the throttle body on a 2017 Camaro SS????
2017 Camaro SS, Roto-Fab, Soler 95mm ported TB, Flow Tech axle back.
Re: Throttle body
Pretty sure they have all been 90 mm since the LS2.
DannyC
Re: Throttle body
Post by DannyC »
Ok thanks. Just wanted to make sure.
DannyC
Re: Throttle body
Post by DannyC »
Holley makes intakes for 2017 Camaro SS that will take a 103mm TB. But nobody makes a drive by wire 103mm throttle body. WTF!!!
Re: Throttle body
Texas Speed, Nick Williams, Seedmaster, all make DBW 102mm TBs for these cars. There are more than that even...
Re: Throttle body
Honestly, no real need to add a throttle body like that to those cars.. not going to do much at all.. would be a waste of time and money...
DannyC
Re: Throttle body
Post by DannyC »
Installed the Solar 95mm modified TB and it works great. I also did a little "smoothing of the plenum inlet. There is a pronounced ridge just inside the opening.
The stock TB is only 88mm and the modified 95 is said to be effectively 100mm when wide open. I think it helps a lot with throttle response.
It's about half the price of the Nick Williams 102mm
