Diablosport InTune S&B CAI Tune???
- 2006 Mustang GT
I have a 75-5003 S&B CAI and was curious if this pre-installed tune in my Intune would be a good starting point for an otherwise stock 2006 GT 3-valve????
- 2006 Mustang GT
Re: Diablosport InTune S&B CAI Tune???
No luck going direct to Powerteq...
- MagsTuning
This referring to the thread in which you already asked about.....https://forum.diablosport.com/viewtopic ... 44&t=82587
The supplied tunes are for a stock vehicle, unless something wild is going on with the MAF curve and S&B states it's a no tune required CAI then your vehicle should behave just fine.
If you feel like something is a miss then log your fuel trims if they're sustained more than 3-5% +/- then I'd say the MAF curve needs to be revised. When logging fuel trims you need to be 1:1 gear, steady throttle input without sudden changes to it.
I'm by no means a Ford tuner but the same principal applies when checking fuel trims. Check around on the forums and find out who the go to tuners are when it comes to tuning Fords with CMR.
- 2006 Mustang GT
Good point.MagsTuning wrote:This referring to the thread in which you already asked about.....https://forum.diablosport.com/viewtopic ... 44&t=82587
With the Bama custom tune, (stock intake thus far) i had fuel trims high enough to set too rich faults - as high as 15%. Bama responded with a more conservative tune, but felt power was way down. The 'canned' Diablosport 91 octane tune feels much better and stronger, although not dyno'd yet.
The attached image is from the 91 Octane Diablosport tune.
- 20200116_081252.jpg (2.95 MiB) Viewed 8253 times
- 2006 Mustang GT
Which way does the MAF curve alter the fuel trim???
- 2006 Mustang GT
Ok...i finally got the S&B CAI on the car this afternoon. The fuel trims at idle improved significantly compared to the stock air intake & filter.MagsTuning wrote:This referring to the thread in which you already asked about.....https://forum.diablosport.com/viewtopic ... 44&t=82587
- 20200119_173836.jpg (2.07 MiB) Viewed 8241 times
This tune is set up perfectly for that CAI, it should be about spot on.
This is not the first time I have heard that our canned tunes felt better than someones custom tunes
- 2006 Mustang GT
Road test results...mikel wrote:This tune is set up perfectly for that CAI, it should be about spot on.
I have just installed the S&B Filters No Tune Required (50 State Legal) # 75-5003 CAI.
At idle, fuel trims hover on either side of zero.
At WOT, fuel trims drop to zero
At 60 mph cruise at 3100 rpm (4th gear) LTFT are 8-9%
Should I alter the MAF curve on this, or would a substitute tune be needed???
Thanks for your support....
P.S. In my InTune 1000, I found a tune labeled 'S&B CAI' but nobody can tell me anything about it....
What tune is loaded?
Assuming its the standard 91 or 93 octane tune, it sounds fine.
- 2006 Mustang GT
mikel wrote:What tune is loaded?
91 Octane Canned Diablosport tune...
- 2006 Mustang GT
Bummed out...
Bama/AM keeps telling me that I have an air leak. I advised them politely that we do a smoke test on everything as SOP and the results are negative. I then advised that when a stock tune is loaded, the trims are normal, even with the S&B intake.
So here is my question...
My car runs better with the 'canned' 91 Octane tune that came in my In-Tune 1000
My only issue is that my cruise fuel trims are in the +7- o 8 % ranges.
Idle and WOT trims are zero.
What can I do - on my own - to bring the trims down to a switching 2-5%???
MAF Curve????
Thanks...
MAF Curve????
Thanks...
I have a few thoughts.
A no tune required CAI generally adds little to no power, so why go through all of this?
I'd put the stock intake back on, load our canned tune and enjoy the 20-25 hp bump.
If you really want a CAI, look into one of the units that we have preloaded tunes for, add it and the appropriate tune, and experience even more power gains.
FWIW, my experience with any 05-10 GT is that if there is a leak somewhere, there WILL be lean codes.
- 2006 Mustang GT
Agree with you on the lack of lean codes...mikel wrote:I have a few thoughts.
Also, i may also return to stock on the intake too.
IAT's are much higher with the S&B over stock.....
- 2006 Mustang GT
Let me say something here...I have a background in competition Motorsports, held three different competition licenses and ran a dyno...so when I say what I am about to say, I mean no disrespect and I do not have a dyno sheet to back up my opinions. Having siad that, i would like to tell you what i have noticed over the past couple of days..
I've switched back and forth between the 'canned' Diablosport 91 Octane Tune that came in my In-Tune and both the 91 Perf and 91 Race tunes written for me by Bama.
The Diablosport 'canned' 91 Octane Tune pulls harder than the 91 Perf or 91 Race Bama tunes.
Overall, the Diablosport tune is smoother and feels more powerful. It also returns to curb idle sooner at a stop sign, but when shifting through the gears, it is smoother because the RPM doesn't drop between shifts like the Bama tune.
The throttle is super touchy with the Bama tune, so much so that it makes it harder to drive the car smoothly. The Diablosport 'canned' tune is easy to drive, yet has a 1 to 1 pedal/throttle relationship.
When I first bought the In-Tune, I ran this Diablosport 'canned' 91 Octane Tune for about 2 years. Then, I decided to take advantage of my 'Free Tunes For Life' offer that came with my tuner. When I loaded the Bama tune, I kept getting a check engine light (CEL) where I had run the Diablosport tune for 2 years with no CEL and passed smog every time. Bama modified the tune, but it still produced higher fuel trims than the Diablosport, even though the CEL was staying off now.
When I contacted Bama/AM, the first thing they told me was my high fuel trims were caused by an intake air leak. I told them that we smoke test every CAI install and it was negative for a leak. Also, I seldom see a Ford that doesn't spit out a lean mixture fault with even a minor air leak. After that, they now want a full set of datalogs to alter their previously provided 91P and 91R tunes,which is - of course - reasonable, but I am starting to feel like I am just getting nowhere...
I am planning on running FRPP Hot Rod Cams soon and I will need a modified tune to support those cams, but now I am not confident that Bama/AM can pull it off, so my question to you is...
Who can I send my datalogs to that could tweak this 'canned' Diablosport 91 Octane Tune and who can alter that tune for me in the future when I switch to Hot Rod Cams???
Here is what the trims look like tonight on the Diablosport 91 Octane 'Canned' Tune after only 21 miles of driving and I usually see the trims drop even lower after 75-100 miles or so.
How does this look so far to you????
those trims are nothing to be concerned with, but could be dialed in a bit.
Check out tpctuning.com for a good email tune option here.
