I received the cable to hook my wide band A/F guage to the i3, but I have no clue where to tap into the ODBII cable or which wires. Has anyone done this and have a "How to"?
Tia,
Danny
A/F guage 5v cable
A/F guage 5v cable
2017 Camaro SS, Roto-Fab, Soler 95mm ported TB, Flow Tech axle back.
- MagsTuning
Re: A/F guage 5v cable
The pigtail you bought from DS is wired to the wideband itself then the pigtail is plugged into the 3.5mm jack on the i3.
Your wideband instructions will show you what wires or pins need to be used for wiring the 5v.
Ok thanks. I'll go get the paperwork that came with it.
Ok I guess I'm really confused. The instructions say the white and brown wires, which are cut in the cable going to the gauge, need to be pinned in position 9 and 10. I did that.
Was I supposed to wire the pigtail into those positions instead of using the white and brown wires already in the gauge wiring??
- MagsTuning
AEM 30-0334 x-series wide band
