PCM Calibration update needed error
Re: PCM Calibration update needed error
they're closed for Christmas holiday.. won't be back until Tuesday...
Technical Support
Telephone: 561-908-0040
rsalgado0520
Post by rsalgado0520 »
Am having the same problem on my Jeep the dealer probably did an update too what do I do?
Skullxminer
Post by Skullxminer »
Bought a i1000 used got it unlocked and now i am getting the pcm calibration update needed error. what do i need to do????
info.xml
(1.76 KiB) Downloaded 740 times
what is the year, model, engine of your vehicle????
ccbenn
Post by ccbenn »
Hello,
I have an I-1000 DCX. My tuner worked 2 days ago then I took it into the dealership for a new thermostat. Now, I get the message:
PCM calibration for 2C3CDXHG0DH571568 might need an update. Check for a calibration update?
Update manager says my tuner is up to date...but I just get the same msg again and again.
Help!
posty the info.xml file from the intune drive please.
ccbenn
Post by ccbenn »
info.xml file attached.
Thanks!
ccbenn
info.xml
(2.33 KiB) Downloaded 650 times
you didn't return it to stock prior to the dealer update, so the device needs to be reset.
give us a call with it powered up and reference that I asked you to call for a reset.
ccbenn
Post by ccbenn »
Thanks Mike!
I'll call Wednesday morning.
Thanks again,
ccbenn
mttsnb
Post by mttsnb »
Hi Mike,
My fuel pump failed and was towed to the dealer where they flashed the PCM. I am now having this same issue where it keeps telling me to do a calibration update but no update is found when I plug into the update agent. Attached is my info.xml. Can you help me get this solved?
info.xml
(1.8 KiB) Downloaded 474 times
if you didn't restore prior to going to the dealer you'll need to call in and have the device reset first.
