2014 ram
Amermuscle
2014 ram
I totalled 2015 which had the unlocked pcm and tuners i2 , the insurance company took my pcm , so I just bought a new licence for the 2014 . I cant seem to get it too find the tcm . Is there a calabration I need to drag onto the i2 for it to read my 2014 . I dont wan a resort too hp tuners . I loved the tcm tune on my 2015 . Andy 2014 currently feels like a pig
Re: 2014 ram
Not all 14 8 speeds are supported.
Please post the info.xml file from the i2 drive so i can check it out.
Amermuscle
Re: 2014 ram
Thanks for the reply mike , can u tell me where to go too look at it ?
- MagsTuning
Re: 2014 ram
Connect your i2 to your computer open the main folder and the info.xml file will be located in it.
Amermuscle
Re: 2014 ram
<?xml version="1.0"?>
-<tool_info platform="I2">
<registration updates="0" tool_oem="DIABLO_D" status="0" sn="1QQGPUUFZP"/>
-<applications count="5">
<application rev="2t04ja" name="vehicle"/>
<application rev="2r01j" name="updater"/>
<application rev="2r01t" name="gui"/>
<application rev="2r01m" name="installer"/>
<application rev="2r01d" name="logger"/>
</applications>
-<databases gui="2r01i" SAE="3r01h" vin="2r01i" dtc="2r01a" dbnames="2r01b">
<database pid="2r01e" tune="2t02ua" mfr="DCX"/>
<database pid="2t01dt" mfr="FORD"/>
<database pid="2t01ct" mfr="GM"/>
</databases>
-<system rev="1r01b" config="1r01e">
<kernel version="#7 Sat Sep 19 01:29:28 EDT 2015" release="3.17.2-diablo2"/>
<option name="Wifi" driver="v4.0.2_9000.20130911" enabled="true"/>
</system>
-<last-connected vin="1C6RR7KT5ES445723" mfr="DCX" ecus="2">
<ecu calid="68153791AD"/>
<ecu calid="68234060AB"/>
</last-connected>
-<licenses tuned="2" available="2">
-<license vin="1C6RR7FT0FS652418" mfr="DCX" ecus="2">
<tuned_ecu calid="68232414AD" type="PCM"/>
<tuned_ecu calid="68242003AE" type="TCM"/>
</license>
-<license vin="1C6RR7KT5ES445723" mfr="DCX" ecus="2">
<tuned_ecu calid="68153791AD" type="PCM"/>
</license>
</licenses>
<reg reg="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"/>
</tool_info>
</applications>
</databases>
</system>
</last-connected>
</license>
</license>
</licenses>
</tool_info>
Amermuscle
Re: 2014 ram
This is what I found on tool not sure if its helpful
Re: 2014 ram
I show your TCM cal to be supported.
You dont see an option for 'modify stock tune' in the advanced tune menu in the TCM portion?
Amermuscle
Re: 2014 ram
Is that something would do in the truck ? I can try again , I have it back to factory currently cause it only picked up the engine. It would be sweet if it took the tcm file
Amermuscle
Re: 2014 ram
So do I not reset to back up after the first tune diablo tune is updated ?
Re: 2014 ram
no just go through the tune menu and after you select the pcm tune tell me if it shows the install standard tune menu again and pick it, and it should show modify stock.
Amermuscle
Re: 2014 ram
So I have the 92 diablo tune on i tried advance tuning reloaded the diablo tune still didnt pick up the tcm , what other tricks could I do . My 2015 picked it up but I didn't 3 years ago
Amermuscle
Re: 2014 ram
If I go too vehical information it has the tcm , but it never asked me to backup or do anything with it.
Amermuscle
Re: 2014 ram
Advance tunes has these dunk if its helpful
Re: 2014 ram
after you select a pcm tune you dont get another install standard tune option with modify stock for tcm?
Amermuscle
Re: 2014 ram
No I tried a couple time over the weekend , reset to factory back up and re read the backup files again put on the diablo tune . . Is there any file I could load onto the tuner to force read the TCM.mikel wrote:after you select a pcm tune you dont get another install standard tune option with modify stock for tcm?
