i've configured the intune (updated today), 2 analog ports (afr and oil) but they don't show up under the dataview external tab..
attached
info.xml
screenshot of dataview
thank you
steve
intune analog ports not appearing in dataviewer
Re: intune analog ports not appearing in dataviewer
load this to the i3 then run the log again.
Hi Mike
failed.. current firmware 1r03m cannot be replaced by ....
screen shot attached.
Thank you
Steve
Thank you
Steve
OK, thats because you are using an i1000, not the i2/i3 like the section of the forum would indicate
That said, you seem to have an old version and you should update the i1 with update agent and see if that helps.
sorry about that...
updated it yesterday still doesn't work, here is the info.xml
its not up to date....way behind honestly.
try again, make sure theres not a group update sitting in the drive.
deleted the group file in the "g:" drive, rebooted and tried again but failed.. no group_update file but its still complaining about one..
also tired on the device, settings, advanced, clear all updates -- response "clear all updates done".. same problem
screen shots
thank you
steve
screen shots
thank you
steve
see if it will import this file.
mike, it worked!
(after applying fix rebooted a couple of times and then i used to update agent.. )
thank you!
thank you!
good deal, enjoy.
