GM 8.1 throttle stick
f4iryder
Post by f4iryder »
Hey guys I have an 04 gmc Sierra 8.1 and after installing the tune if I take it past 1/4 and let off the throttle will stick. I've confirmed it is the tune as it doesn't do it stock. I've done the updates and it does the same thing. I'm pretty ignorant when it comes to computers so I'm not sure how to copy files or any of that. Any help would be appreciated.
Re: GM 8.1 throttle stick
use the attach option below to post the files from the tunes folder and we'll provide a fix.
f4iryder
Post by f4iryder »
Thanks mikel, I'm pretty illiterate when it comes to this stuff how do I get those files for you?
f4iryder
Post by f4iryder »
here you go buddy, hopefully these are the right ones?
PCM_12587703_LastTuneWritten.grg
(32.74 KiB) Downloaded 220 times
PCM_12587703_Backup.grg
(32.65 KiB) Downloaded 229 times
pretty sure you sent these to rich as well, but this will fix it.
PCM_12587703_MOD.grg
(30.63 KiB) Downloaded 221 times
f4iryder
Post by f4iryder »
I did and thanks I appreciate you guys. Do I need to flash the truck back to stock before I copy this to the drive?
nope, just load it to the drive then to the truck.
f4iryder
Post by f4iryder »
Got it works perfectly now. Thanks a lot I appreciate it
