engine light
engine light
I put a 180 stat in my magnum RT. I live in Coral Springs so you know the weather. I have been getting an engine light at least once a week and the Predator code indicates thermostat. Any suggestions?
RE: engine light
P0128?
RE: engine light
So are you saying the thermostat is bad?
RE: engine light
What is the engine light for, go to diagnostics show trouble codes so you can get the exact code for the light.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
RE: engine light
Ok....I'm in idiot. In my defense, I did party a lot in college.
RE: engine light
Heh, wait a minute. You can't get off that easily... What was it?
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
RE: engine light
Hi
Sorry I did not respond with the code. I cleared it just before you asked me what the code was and I was not sure. The light came on again and you are correct it is P0128.
RE: engine light
The correct part number is, 4128. Since this one was given to me, by the same guy that sold me the Predator, I assumed it was correct and installed it. I am going to purchase another one and install to see if that clears the problem.
RE: engine light
4128 is correct number for 180 t-stat, I believe from autozone. I have one in my car in orlando and never got a code, even when temps were in upper 40's
Re: RE: engine light
It will have 4128 stamped on it and on the other side it has Motorad stamped on it. It actually opens at 185* (or should). When you install it orient the bleeder hole up.BOB51 wrote:The correct part number is, 4128. Since this one was given to me, by the same guy that sold me the Predator, I assumed it was correct and installed it. I am going to purchase another one and install to see if that clears the problem.
If the engine doesn't warm up to somewhere around 170* or over for some amount of time you'll throw the code. I think that may apply across starts too? You're not commuting like 2 miles to work and back are you? Watch the temp on your EVIC diagnostic display. Hold both lower, inside buttons down at the same time for about 8 seconds. Then use the up and down buttons to get to the screen with the coolant temp. leave that on while driving. Should look like this:
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
RE: Re: RE: engine light
I just realized I did not orient the bleeder hole up. This was pointed out to me by one of the club members at Hooters on Sunday. I will open it back up and correct the problem. Hopefully that will take care of the issue.
Re: RE: Re: RE: engine light
I know it's supposed to be up but I don't know what the effects of being down would be. Don't know if the trapped air would effect the temp sensors?BOB51 wrote:I just realized I did not orient the bleeder hole up. This was pointed out to me by one of the club members at Hooters on Sunday. I will open it back up and correct the problem. Hopefully that will take care of the issue.
You have a meat thermometer? When you re-install put it in a pot of water on the stove and see where it opens (and closes).
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
RE: Re: RE: Re: RE: engine light
Mine doesn't even have a bleeder screw (NAPA 165). That shouldn't affect the temps.
I opened the thermostat back up and the bleeder hole was at the very bottom. Put the hole at the top and put it back together. I will let you know if it has any affect. Thanks Everyone
mine doesn't either
