2015 3.5L EB.... Misfire? Code P0D00????
jadugargomes
Post by jadugargomes »
Im sorta having a issue with 2015 3.5L Eco. I bought it used 50,000 miles for a real good price. I immediately ordered a inTune2. I ran a tank of 93 without tuning, then filled it up with 93 and added an Octane Booster.
Then I tuned it with the 93 tune. No problems for about a month, then i started getting a ticking sound when accelerating from cruising speed, boost would shoot up then the wrench would pop up, and it says check manual.
Id limp it home, then check the trouble code and it came back with PCM:P0D00- ISO/SAE Reserved. I clear the code, and it would happen again. It only ticks and happens when the engine is under a load. Cruising normal speeds is fine. Any help?vidmate mobdro word counter
Re: 2015 3.5L EB.... Misfire? Code P0D00????
does it do it without the tune as well?
smithclarkson02
Post by smithclarkson02 »
mikel wrote:does it do it without the tune as well?9appsapk.vinvidmateapp.vinvlc.vin
No reply..? Have the same question.
Return to “i2/i3 for Ford vehicles”
