Hi all,
so a quick question on trans tuning, specifically shift points. From what I've read here and elsewhere, I understand that for (or most) 2014 Ram 8 speeds, we cannot tune or change the shift points for our vehicles. Is there anyway to be able to do this? Reason for asking is that I've installed a new cam but with the low shift points (well below 6000 rpm), the benefits of a more open cam are negated.
Any input or suggestions appreciated,
Thanks.
2014 RAM 8 speed (Transmission tuning)
Re: 2014 RAM 8 speed (Transmission tuning)
some 14 ram tcm cals are supported.
Post the info file from your device so i can check it out.
davidjacobs
Hey Mike,
.xml file uploaded. I suspect I'm one of the unlucky few.
Cheers,
david
Cheers,
david
Yeah, unfortunately this is not a cal thats shared with 2015, 68234060AB.
