2014 ram
Re: 2014 ram
set it back to stock then call in and ask to force a calibration update, mention that I asked you to call for this.
Amermuscle
Re: 2014 ram
Thanks mike I'm off friday I'll call asap so I can get this going . I appreciate all your help!
Amermuscle
Re: 2014 ram
So I recently had too replace the transmission, I cant get my i2 to read the tcm off this unit . What should I do . It is the same handheld
Amermuscle
Re: 2014 ram
Look like it still can read my tcm but wont back up a file just the motor again.
Amermuscle
Re: 2014 ram
@mike should do you think it needs another force calibration to read the new tcm ?
Re: 2014 ram
did you return to stock before you had the tcm replaced?
post the current info.xml file from the device please.
Amermuscle
Re: 2014 ram
Yes I returned to stock before I brought it in .
Amermuscle
Re: 2014 ram
Does any of this help
Amermuscle
Re: 2014 ram
This is what I pulled when on computer. I'm off by the time u read this let me know . Jay greene usually helps me tune but cant get the tcm too read.
Re: 2014 ram
can you post the actual info file here please?
Amermuscle
Re: 2014 ram
<?xml version="1.0"?>
-<tool_info platform="I2">
<registration updates="0" tool_oem="DIABLO_D" status="0" sn="1QQGPUUFZP"/>
-<applications count="5">
<application rev="2t04ja" name="vehicle"/>
<application rev="2r01j" name="updater"/>
<application rev="2r01t" name="gui"/>
<application rev="2t01oa" name="installer"/>
<application rev="2r01d" name="logger"/>
</applications>
-<databases gui="2r01i" SAE="3r01h" vin="2r01i" dtc="2r01a" dbnames="2r01b">
<database pid="2r01e" tune="2t02us" mfr="DCX"/>
<database pid="2t01dt" mfr="FORD"/>
<database pid="2t01ct" mfr="GM"/>
</databases>
-<system rev="1r01b" config="1r01e">
<kernel version="#7 Sat Sep 19 01:29:28 EDT 2015" release="3.17.2-diablo2"/>
<option name="Wifi" driver="v4.0.2_9000.20130911" enabled="true"/>
</system>
-<last-connected vin="1C6RR7KT5ES445723" mfr="DCX" ecus="2">
<ecu calid="68153791AD"/>
<ecu calid="68234060AB"/>
</last-connected>
-<licenses tuned="1" available="2">
-<license vin="1C6RR7FT0FS652418" mfr="DCX" ecus="2">
<tuned_ecu calid="68232414AD" type="PCM"/>
<tuned_ecu calid="68242003AE" type="TCM"/>
</license>
</licenses>
<reg reg="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"/>
</tool_info>
My login been weird threw computer . So I had to email my self the file then send it threw phone .
</applications>
</databases>
</system>
</last-connected>
</license>
</licenses>
</tool_info>
Re: 2014 ram
and we are discussing the 2014 VIN here correct?
1C6RR7KT5ES445723
1C6RR7KT5ES445723
Amermuscle
Re: 2014 ram
Yessir , i did a force calibration about 2 months ago to read the tcm , and the tranny went I just replaced it threw the dealer . I went to retune and tool told me too go update the tool and i did . And i went back to truck and only read the pcm .
Re: 2014 ram
Can do the same here, we can force it back to the AA cal that we support.
