I had my 2000 F250 in the local ford garage for a little work, when I went to pick it up they said the truck was throwing a code so they checked it and fixed the problem. But they said they also flashed my pcm, now my programer wont recognize my truck, btw I had it set on the 60hp setting.
What should I do?
Ford reprogrammed my PCM, now...
Re: Ford reprogrammed my PCM, now...
Please call tech support and they will require proof of dealership reflash for verification. They will be able to get you up and running after you speak with them.cocco78 wrote:I had my 2000 F250 in the local ford garage for a little work, when I went to pick it up they said the truck was throwing a code so they checked it and fixed the problem. But they said they also flashed my pcm, now my programer wont recognize my truck, btw I had it set on the 60hp setting.
What should I do?
Cole Stevens
I just faxed over my work order from the ford garage today and talk with a tech guy here at diablo sport. We went through and he gave me a code to unlock the programer. It seemed to work but when I went to install a program it still comes up saying "tool not licensed for this vehicle" It also still shows the last program written was the 60hp one.
Any more advice?
Any more advice?
