P0601 After T2
jwolf199
P0601 After T2
Post by jwolf199 »
I used an I2 initally for my 2017 Hellcat. I went back to original backups then had my tuner make the cal files for the T2. Now I am getting a consistent P0601 Code. Anything I should be worried about?
2019 Ram - Custom Greene Racing PCM and TCM Tune
2017 Charger Hellcat - Tim Barth Tuned
2020 Jeep Wrangler Rubicon Recon
Re: P0601 After T2
did the t2 do a calibration update when you first connected it?
You can simply have that code disabled in the tune.
rkuzniewski
Re: P0601 After T2
Post by rkuzniewski »
I worked with Stephen Richardson back in February on this P0601 Error Code. Case 455463. He sent me a file that temporarily fixed this error code. He mentioned that a permanent fix is being worked on. Is that permanent fix out yet? Please let me know. Thank you.
Bob K.
Re: P0601 After T2
Im told its done and being tested, hoping to be able to apply these fixes in the field this week.
jruzarme
Re: P0601 After T2
Post by jruzarme »
Hi guys,
I am having a similar issue with my 2015 Hellcat. I just got 10 days ago the T2 and unlocked PCM ... when I loaded the tune P0601 came up ... i have got this behavior repeatedly, I delete code with the T2 and even with just turning ignition off and then back to ignition run, not even start the car the code is back.
Any news on fixes coming up? I did update my T2 5 days ago and reloaded the tunes, but still there.
Thanking you in advance Jaime R.
Been using you guys forever with my rides
Re: P0601 After T2
fix is close, but for now post the last tune written and I will disable it for you.
jruzarme
Re: P0601 After T2
Post by jruzarme »
Hi Mike,
Thanks a lot for your replay. I would really appreciate that.
I am uploading the tune I am using, LMI91 octane with a slight mod to the fun temperature since I am using 180T stat together with Mishimoto radiator. So basically the tune is a LMI91 with 205F for the fan.
I did an update to T2 yesterday and reload tune but p0601 still there and p0128 as well.
I would be delighted if we can disable both codes
Thanking you in advance,
Jaime Ruz
Re: P0601 After T2
jruzarme wrote:Hi Mike,
Jaime Ruz
here yo go, no more codes with this tune.
jruzarme
Re: P0601 After T2
Post by jruzarme »
Wow!
Thank you sooo much!
Just had a chance to upload it and it worked perfectly!
No code seen no more.
:D :twisted: :twisted: :twisted:
rkuzniewski
Re: P0601 After T2
Mike,
Do you supply a temporary tune or was that the permanent fix tune?
Robert K.
Re: P0601 After T2
a permanent fix is coming soon.
rkuzniewski
Re: P0601 After T2
A permanent fix is coming when??? When hell freezes over? I have been waiting since the end of April for a fix!
sbenja2008
Re: P0601 After T2
Post by sbenja2008 »
rkuzniewski wrote:A permanent fix is coming when??? When hell freezes over? I have been waiting since the end of April for a fix!
It will never be fixed I've been waiting since June of 2019 for a fix on the EAS data logging and still nothing they are all talk and no action.
Dragon23
Re: P0601 After T2
Post by Dragon23 »
You probably have a gigantic list of issues on the t2, how about sending the new version as is, and keep working on what you are struggling with, EAS.
don't hold all the rest of the problems back to do it all together, that is dumb for busyness. how long has this tool been out and how many updates have there been ?
1 is that about right ? my 60 $ Kodi box has had more.
