Ignition not recognising i2 tuner
jonmoody
Post by jonmoody »
I'm getting an error in the Ignition Updater (per the attached) when connecting my i2 to a Mac
Effectively saying it's an unrecognised DiabloSport device?
Any immediate things I should be doing (apart from calling support?)? Thanks.
Re: Ignition not recognising i2 tuner
uninstall the current updater then download this one and install it:
https://drive.google.com/file/d/1X24Arc ... sp=sharing
jonmoody
Post by jonmoody »
Unfortunately still the same result.
Deleted old installer and downloaded / installed the below one.
Still coming up as an unrecognised device?
hmm, this has resolved the issue for many others.
Can you confirm the version of ignition it displays when you open it?
jonmoody
Post by jonmoody »
Thanks for the quick reply Mike.
I don't see a version number on ignition itself (I'm running a Mac and no 'About' type menu), but I've included the info.xml and version.txt from the device itself if that's helpful.
I'm based in Oz, hence the weird reply times.. Thanks.
Jon
no version on ignition like this?
jonmoody
Post by jonmoody »
Mike
Unfortunately not - per the attached. Am I still using the wrong version perhaps?
Jon
hard to say. Did you do a full uninstall of the previous one before installing the one from here??
jonmoody
Post by jonmoody »
Yep - certainly did.
Full removal / clearing of trash all that good stuff.
The downloaded zip (.pkg) file does refer to Mac 1.0 - is this the right one still - doesn't really look very different to the original one.
jonmoody
Post by jonmoody »
Thanks for all you help Mike, but I'm still getting that same unrecognised diablo device error.
Any other thoughts or is the device busted?
jonmoody
Post by jonmoody »
Mike - you'll be pleased to know that I have used a Windows laptop and have updated my i2 successfully. Not sure what was happening with the Mac ignition... Thanks for all the help.
Odd, will ave to look into this as this has been resolving he same issue for several other mac users.
Macs are very iffy/finicky with tuning stuff/software.. it's ALWAYS best to use a Windows PC/laptop with this stuff.. always! Never use a Mac...
Dunger
Post by Dunger »
I’m having a similar issue. Ignition says that it will start when the device is plugged in but when I plug in my Intune I3 nothing happens. I’m also using a Mac. When I go to Finder I can see that my I3 is plugged in.
I did all the updates that I could using WiFi but when I try to tune the vehicle (2018 Silverado) I get the message that “one or more ECUs require an update….. please plug into pc for update)
To complicate things even more this was a used DiabloSport I3 but was purchased from another owner of a 2018 Silverado and he had used it for a custom Diablew tune. It was unmarried and showing 0/1 for licensing.
I’m hoping it’s not a huge hassle.
I’m going to call Diablo tech support tomorrow to see if there is an easy fix.
Return to “Ignition updater”
