Device Error Update Agent/i3
Stevep0070
Post by Stevep0070 »
plugged in my i3 tuner and it starts to read runtime.zip and then gives this error screen. Any way to fix this today? It Saturday so the office isn't open.
Stevep0070
Re: Device Error Update Agent/i3
Says that it cannot find Runtime_03.dbg. I looked in the runtime folder of the device. Sure enough it isnt there. How can i fix this?
Orrank
Post by Orrank »
Same issue with my T2
Monday is a Federal holiday.. so they won't be back in the office until Tuesday May 26th.... PLUS keep in mind that they are working on a skeleton crew due to the CoronaVirus... so less people in the office, less people answering the phones, etc... things aren't happening as quickly or as smoothly as they normally do...
Orrank
Post by Orrank »
Yea, to be expected. Hopefully its an easy fix.
Two vehicles without tunes, Stock sux
Stevep0070
Looking through several posts over the weekend and I’ve seen sometimes Mike is having people delete the entire contents of the runtime folder. I have 2 licenses (one ford one Chevy). The ford has an active tune installed. The Chevy is sitting factory right now. Lew do you know if emptying the runtime folder would fix it? What adverse effects could that cause? If you don’t know for sure I understand. I just figured with all your experience with these tuners you may have an idea on how to get us up and running without having to add more calls on to their Skelton crew. Thanks!
sorry guys, this was resolved this morning, updates will work as expected.
Return to “Ignition updater”
