Trouble with data logging
Oconer
Post by Oconer »
trying to datalog but the numbers are not correct. Easiest ones to notice are the Temps. You can clearly see on data viewer that ect and act are reading negative, also obviously air temp and coolant temp are not that cold. Lots of other numbers not right either but those are the easy ones to check. Also whenever I log VIA trinity by itself and then pull it up to dataviewer no important PIDS are shown, only time I could get all the default DCX PIDS is when I log via live log on my laptop.
NEWMOTORLOG2.log
(63.68 KiB) Downloaded 290 times
Oconer
Re: Trouble with data logging
Post by Oconer »
Also have the recent update, I even unmarried the device and reloaded the tune I was sent by my tuner. Don’t know what else to try
what vehicle is this?
Oconer
Post by Oconer »
It’s a 2007 SRT8 dodge charger
OK, uninstall dv, then install this one.
When it asks to update, click no, this should work for you for now.
https://forum.diablosport.com/download/ ... p?id=12633
Oconer
Post by Oconer »
Awesome I’ll give it a shot when I make it home, thanks!
Oconer
Post by Oconer »
Another question, would I have to record another log? After installing 3.3? and will this fix the missing PIDS?
the existing logs should open properly and look ok in the old dv.
