Hello!
Trying to use DCX on 2013 RAM 1500 5.7.
After repeated attempts, each time I received a message in my Diablo device "PCM Calibration for 1C6RR7GTXDS706156 might need an update. Check for a Calibration Update?
Update Agent each time says your device is up to date.
What should I do to make it work?
Best regards,
Gleb
DCX PCM Calibration needed
White ShadoW
Re: DCX PCM Calibration needed
copy this to the root of the intune drive and let the device import it then load it tot he pcm
White ShadoW
Thanks for fast answer! It's helped and tuner works fine.
I didnt find option to tune axle gear ratio on this truck via intune tuner. Is there such option?
I searched modify stock tune parameters.
