Caliber SRT4 WOT BOX Causing limp mode
- Csrt4jimpo
I'd like to run my WOT BOX with the canned 93 tune for now till I get a custom tune. What can I do to allow the tune to not send the car into limp mode when I activate 2 step and WOT shift?
2008 Caliber SRT4 #1547
Re: Caliber SRT4 WOT BOX Causing limp mode
load the tune then post the last tune written file here.
tech@diablosport.com
- Csrt4jimpo
- Csrt4jimpo
Heres my backup tune and the 93 tune that I will be using.mikel wrote:load the tune then post the last tune written file here.
Thanks!
- PCM_05187661AF_Perf_93oct.drg
- (3.25 KiB) Downloaded 338 times
- PCM_05187661AF_Backup.drg
- (781.16 KiB) Downloaded 345 times
here you go
- PCM_05187661AF_2step.drg
- (573.77 KiB) Downloaded 379 times
- Csrt4jimpo
Ok so I installed the tune. As soon as I 2 step, check engine light comes on and goes right into limp mode still... am I missing something?mikel wrote:here you go
Not sure...post the last tune written please.
what was the code?
what was the code?
- Csrt4jimpo
Heres the last tune written, I'm using a trinity if that changes anything. Codes are P2302, P2305, P2308, and P2311 all for the ignition coils. I appreciate all the help.mikel wrote:Not sure...post the last tune written please.
what was the code?
- PCM_05187661AF_pcm_05187661af_2step.drg.drg
- (1.25 KiB) Downloaded 314 times
you didnt load it properly.
You selected the same tune as the tune to load and as the backup.
You must select a copy of the stock tune as the backup when prompted so the tool can see the differences and send them to the device.
Hi, I have a Diablosport Trinity on the 93 octane tune. I am having the same problem with the N2MB WOT box 2 step feature. DTC codes are P2302, P2305, P2308, P2311, P0300. Any help would be appreciated! Thank you! Attached are my backup and current tune files.... Please let me know if any other info is needed.
- PCM_05030394AM_Perf_93oct_modified.drg
- (3.25 KiB) Downloaded 243 times
- PCM_05030394AM.drg
- (781.01 KiB) Downloaded 234 times
here you go.Tsmacz wrote:Hi, I have a Diablosport Trinity on the 93 octane tune. I am having the same problem with the N2MB WOT box 2 step feature. DTC codes are P2302, P2305, P2308, P2311, P0300. Any help would be appreciated! Thank you! Attached are my backup and current tune files.... Please let me know if any other info is needed.
- PCM_05030394AM_2_step.drg
- (573.7 KiB) Downloaded 290 times
Thank you, I'll let you know if any other issues.
