2019 Charger Scat Pack Engine won’t start after install PCM
m7alfayez
Post by m7alfayez »
Good day DiabloSport team,
I hope you’re in good health.
I have a 2019 Dodge Charger Scat Pack and recently I bought PCM and Trinity device from your website. I did the installation by following the instructions for installing the PCM but the car won’t start and the security light is on.
I re-installed the OEM PCM and everything is ok. So could you please advise what is the issue?
Thank you,,
2019 Dodge Charger Scat Pack:
- AFE Momentum GT Cold Air Intake System.
- Hellcat Dynamic Air Scoop.
- JBA 1 3/4" Stainless Longtube Headers.
- Mishimoto Thermostat.
- Billet Technology Oil Catch Can.
Re: 2019 Charger Scat Pack Engine won’t start after install
theres a few threads discussing this, and there are instructions in the box with the pcm that explain the process of reading data from the stock pcm that has to be loaded t the new pcm before it will run the car.
On a JL or any 19+ model dodge/jeep/ram, a replacement/modified pcm will not work until you have followed the instructions on the paper in the box with the pcm.
m7alfayez
Post by m7alfayez »
Thanks Mikel.
Mistakenly I threw that paper. Kindly attached here.
Thank you.
mikel wrote:theres a few threads discussing this, and there are instructions in the box with the pcm that explain the process of reading data from the stock pcm that has to be loaded t the new pcm before it will run the car.
m7alfayez
Post by m7alfayez »
Hello,
If you mean that paper. Yes, I followed.
Got it from Youtube but I’m not sure if that instructions works for 19 also.
m7alfayez
Post by m7alfayez »
Hello,
I would like to update you I followed this topic https://forum.diablosport.com/viewtopic ... 69&t=77842
nd everything is working fine now.
Thanks a lot!
glad to hear it.
I'll check on the papers not being in the box.
Return to “General Support”
