T2 reading incorrect data from vehicle
Re: T2 reading incorrect data from vehicle
This update is live, please update the device and let me know if there are still issues with the PID data.
bgdawgjr
Post by bgdawgjr »
Mike,
I have been trying to update the device via Update Agent and it will go through the motions as if it successfully updates but if you re-open Update Agent it will tell me the same update is available again. "Package r297 (2 files)" I have attached a screenshot of the "Update Available" page. Is there a way you to send me the update and I can try to push it from my PC rather than through Update Agent?
f its reloading the same one its just a bug, but no need to keep loading it, it was good to go the first time :)
bgdawgjr
Post by bgdawgjr »
Well then that's unfortunate as the PIDs still do not work correctly. I tried resetting factory default PIDs but that had no effect either.
I have attached the current version screenshot, not sure if you need anything else.
bgdawgjr wrote:Well then that's unfortunate as the PIDs still do not work correctly. I tried resetting factory default PIDs but that had no effect either.
can you please clarify whats not working correctly?
bgdawgjr
Post by bgdawgjr »
Sure, the TOT PW1 for Cylinder 1 injector reads 0, the KNK ST is stuck at 1, and both of my STFT that should be fluctuating are both stuck at -100%.
My old InTune2 still works for me to create logs but these should work. Also, I am unable to adjust shift points beyond 6K with my Tranzformer, is there a way to have the T2 read from the shift table being modified by the Tranzformer to allow for 6400 to 6600 shift points?
I have also attached a short log at idle to show which PIDs are being recorded.
well, I expected this to be fixed. Can you please post the current info.xml file from the t2 drive so we can sort this out?
bgdawgjr
Post by bgdawgjr »
My apologies for the late response, been busy these past couple of weeks. Attached is the .XML file for you. Let me know if you need anything else.
