Update Agent
Dragon23
Update Agent
Post by Dragon23 »
I noticed that update agent had a up date, not sure if I should have now.
I'm not able to save data logs on the tool.
I get a unexpected error which it saves the error and then continues to try and save the data log, without success.
I let the update program try a few more times to update, and after re boot I managed to get a photo of the error.
here is my XML file with photo.
Dragon23
Re: Update Agent
Post by Dragon23 »
I thought Id try my other computer and It says this.... yikes I'm thinking of trying a third
Dragon23
Re: Update Agent
Post by Dragon23 »
I can see what is missing from the XML, could I copy and paste my last known good XML ? or would that not be a good idea.
Dragon23
Re: Update Agent
Post by Dragon23 »
Okay, so I did copy the previous XML file in place of the bad one and I was able to run the updater again. This time it updated and it said successfully updated, and there are no errors, but it still will not save a data log on the tool and recording through lap top is a crash.
So I'm going to leave this alone.
Mike I'm getting a remote Dyno Tune revision on Thursday, at this point I'm not concerned about EAS logging, but I will need, lap top logging ability's with the tool for my Tuner.
Can you send me the last Data Viewer before the EAS update so I can test the tool will be okay, I'm sending the new XML file from tool as well
Re: Update Agent
can you confirm the dv version you are trying to stream to currently?
Dragon23
Re: Update Agent
Post by Dragon23 »
3.4.4.17
