Failure trying to update I1000 results in error
Trying to update an unmarried I1000 using Igniter application and receiving an error indicating not enough room on device. Pic of error attached.
Re: Failure trying to update I1000 results in error
that ollllld inTune i1000, is ollllddddd man... there are no new updates for it - update software will not work for it... it was discontinued many many many many years ago... there is nothing new for it man... it's done...
this is an i1000 not an i2?BryGuy wrote: Wed Jan 20, 2021 5:51 pm Trying to update an unmarried I1000 using Igniter application and receiving an error indicating not enough room on device. Pic of error attached.
post the iinfo.xml file from the intune drive please.
mikel wrote: Thu Jan 21, 2021 10:15 am this is an i1000 not an i2?
Yes, I1000. So an update. After receiving the error previously mentioned, and closing the updater, the unit continued to update and cycled through a coupled of writing/verifying cycles. It took about an hour but the end result indicated that the updates were successful. I asked the previous owner about what looked to be some I2 files I saw on the unit through the windows file explorer before the update to see if he uploaded them but have yet to hear back. Regardless, those files seem to be gone now with the successful update. The issue now is when I plug the unit into the vehicle, the 'Parameters' option is greyed out - see attached screenshot. Also attached is the xml file and a screenshot of the license status. The previous owner said he paid Diablosport to have the unit reset. I can pm you his name if required so you can verify against your records. Thank you for your assistance.
I know lol but my 6.1 is also very old as am I. I've had a few of these and had a Trinity as well but never used all of the functions. This is fine for what I need on the 6.1. I also have a 6.4 and will buy something newer for that when the time is right.06MonteSS wrote: Wed Jan 20, 2021 11:30 pm that ollllld inTune i1000, is ollllddddd man... there are no new updates for it - update software will not work for it... it was discontinued many many many many years ago... there is nothing new for it man... it's done...
One more update. I just ran the Igniter tool again and it looked like it found an update and very quickly applied it. Took less than 15 seconds. The only difference between yesterday and today was that the unit now has my vehicle info stored as the last vehicle when selecting Vehicle Info'.mikel wrote: Thu Jan 21, 2021 10:15 am this is an i1000 not an i2?
so is it working now?
No, the Adjustable Parameters icon is greyed out when plugged into the vehicle - see attached.
On another note, I spoke with the previous owner. He said Diablosport reset the unit back in April or May of 2020 but after the reset to unmarry the unit, the unit did not work on his vehicle and he was told at that time that the unit would not work on a 2009 Charger Daytona 5.7. Is that true?
is it an i-1000-dcx?
Please post the infoi.xml file from the intune drive.
I have attached the file. I don't think it's a DCX. Text of file below. If it is a DCX, that would be ok because I could use it on my 2012 300 6.4 instead of the intended 06 300 6.1.mikel wrote: Fri Jan 22, 2021 4:20 pm is it an i-1000-dcx?
<tool_info>
<main full_version='InTune-1r04j 03/14/2016 10:51:37 AM' sw_rev='1r04j' svn='9115'/>
<registration sn='CIER686-1' status='1'/>
<cal_id PCM='05030232AF' CM1='04692392AKkg0c0'/>
<restore id='0' vin='2C3LA73WX6H248090' bc='0'/>
<system_db info='1r01b' dtc='1r01a' vin='1r01g'/>
<db mfr='DCX' tune='1r01f' pid='1r01b'/>
<db mfr='FORD' tune='1r02h' pid='1r01b'/>
<db mfr='GM' tune='1r02u' pid='1r01a'/>
<license avail='1' tuned='0'/>
<updates count='5'/>
<oem tool_oem='DIABLO'/>
<reg reg='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'/>
</tool_info>
you wont see the param icon light up until the device is married, once it has saved the stock tune.
Gotcha, it's been awhile since I've used one. So I would select 'Write Vehicle' on the opening screen to start? Appreciate your time so far.mikel wrote: Mon Jan 25, 2021 2:46 pm you wont see the param icon light up until the device is married, once it has saved the stock tune.
yes, go there and select a tune and let it load it, then go back and look at the param menu.
Thank you for the time you've taken to respond. I was able to load a tune onto my 6.1 and everything seems ok. This unit should work on a 2009 hemi 5.7 though yes?mikel wrote: Tue Jan 26, 2021 4:39 pm yes, go there and select a tune and let it load it, then go back and look at the param menu.
Yes indeed.
