Returned to stock then vehicule not supported
lariatsc
Post by lariatsc »
I have been using my i2 on my Ford 3.5 ecoboost since 2019 with no issues. I had to return to stock to go to the dealer for a software update (recall) I tried to tune it back and it says that my vehicule is not supported. I've tried to update my device without results, what happened?
lariatsc
Re: Returned to stock then vehicule not supported
Post by lariatsc »
Here is what I am getting now
can you post the info.xml file from the i3 drive?
lariatsc
Post by lariatsc »
Here is the file
info.xml
lariatsc
Post by lariatsc »
Posted the file...
lariatsc
Post by lariatsc »
Mikel can you have a look at my info file please?
its not showing an unsupported string here. My guess is there may be a communication issue? Confirm it shows VIN in the tool info menu under the ? on the home screen.
lariatsc
Post by lariatsc »
I tried to update my I2 this morning and it worked this time, don’t know why! I did tune my truck with the 87 tune and it went through...the only difference is that the unit gave me a choice for the tcm...it was not the case before
Glad to hear it.
