T2 / Are the other options affected if I customize the tune?
m7alfayez
Post by m7alfayez »
Hello,
I’m sorry my first language not English :( and I have a question.
I got custom tune, and my car is little bit Rich and I need to lean it few. When I go to the customization option I see the options set as 0 input, it seems the tuner he didn’t do anything. So, If I modified the WOT and I saved the tune. The device also will saved the other options as 0 which my tunes settings will be cleared because all the options set as 0.
Thank you.
2019 Dodge Charger Scat Pack:
- AFE Momentum GT Cold Air Intake System.
- Hellcat Dynamic Air Scoop.
- JBA 1 3/4" Stainless Longtube Headers.
- Mishimoto Thermostat.
- Billet Technology Oil Catch Can.
Re: T2 / Are the other options affected if I customize the tune?
you will not see the changes made by the custom tune in the user defined parameters.
m7alfayez
Post by m7alfayez »
mikel wrote: Tue May 11, 2021 10:39 am you will not see the changes made by the custom tune in the user defined parameters.
Thank you Mikel, so if I made one change on the custom tune it will overwrite and touch the entire the tune? Or just what I changed. The parameters with 0 input the device after save my changed will read it as 0? like stock tune :?
it will only change what you change.
Return to “T2 for Dodge/Chrysler/Jeep/Ram”
