Wideband readings off
my readings on trinty 2 are off my eas is hooked up to white wire 5v and my aem is reading 14.7 like it should at idle but trinty is reading 13.7 at idle how can i adjust?
Re: Wideband readings off
did you scale it using the values provided by AEM?
not sure how do i go about doing that mike?
you have to enter the upper and lower bounds for the 0V and 5V values for the device to know what to display for the incoming Voltage reference.
