Unable to log analog inputs for wideband
jd40
Post by jd40 »
I'm trying to log my wideband but for some reason ever since last September-octobers dataviewer update I can't choose to record any external PIDs. and when I try to record with just the i3 the analog inputs never show up in miscellaneous or any of the other tabs. I had called tech support a few days ago but was just told to try creating new analog inputs and it should show up in miscellaneous, it does not.
duster360
Re: Unable to log analog inputs for wideband
Post by duster360 »
Mike, Brian
Any update on fixing why the I3 Analog input cant datalog?
Needless Torque Calibrations
www.needlesstorque.com
I'll have to look into where this is at, I thought a fix had been pushed out.
Last i recall the tool is recording them properly, its a DV display issue.
killface
Post by killface »
My i3 is doing the same thing now. I know everything is connected correctly but it doesn't record AFR.
duster360
Post by duster360 »
mikel wrote: Thu May 13, 2021 8:56 am I'll have to look into where this is at, I thought a fix had been pushed out.
It has seemed to have broke sometime AFTER 3.4.1.4 version of DV.
