Did i2 upgrade fail?
legacybg555
Post by legacybg555 »
I connected i2 to a Windows PC and updated it by i2 updater and ignition.
The update seems to be successful, but the Database information is missing. Is this normal?
See attached before and after Database Information description.
If it is abnormal, please tell me how to fix it.
In the current state, pressing the Application Information button freezes the i2 itself.
Re: Did i2 upgrade fail?
please post the info.xml file from the i2 drive.
legacybg555
See attached info.xml. Please check and advise.
sorry, just realized you were using the old i23 updater.
Please install the update agent software form our website and use that, i2 updater hasn't been used for some time now.
https://fusionupdate.com/ignition/power ... taller.exe
legacybg555
thank you. Try retrying with this updater.
legacybg555
It seems that the update was successful.
Thank you
good to go :)
