Knocking during 1-2 shift.
blue99rt
Post by blue99rt »
2008 Ram 1500 Quad Cab 5.7L 4x4 (1/2 ton, NOT MegaCab). Diablesport InTune I1000
During moderate to heavy throttle I get a ratcheting noise during the 1-2 shift. It does not happen during WOT. It only happens when a tune is installed; any tune including MPG boost. I can not duplicate when there is no tune installed. It sounds similar to a spark knock but only happens during the shift; nothing before or after. I installed a K&N CAI and a Dynomax cat back and nothing changed. Any guesses?
WildHorse
Re: Knocking during 1-2 shift.
Post by WildHorse »
Showing +(positive) knock in the logs ?
Gʀᴀʙʙᴇʀ Bʟᴜᴇ 2017 Mᴜsᴛᴀɴɢ GT 300A
blue99rt
Post by blue99rt »
I was able to record 3 pulls this morning. How do I read the logs?
So this happens when shifting at part throttle?
Post the log please.
tech@diablosport.com
WildHorse wrote: Mon Oct 18, 2021 5:44 pm Showing +(positive) knock in the logs ?
dodge doesnt play the +/- game
If there is KR on a dodge, it means something bad happened and the pcm is pulling timing as a result ;)
blue99rt
Post by blue99rt »
OK, here's 2 logs. On the "00" log I duplicate the issue 3 times back to back; 1/2-3/4 throttle, 1-2 shift. To me, it SOUNDS like a noisy trans solenoid (like a Chrysler 604 or 42LE), but I cannot duplicate it with a stock tune. It only happens DURING the shift. This is the 87 octane tune with 87 pump gas.
On the "01" log I did WOT 0-90 mph; I did not hear anything there.
2008ram1500hemi57_01.log
(49.37 KiB) Downloaded 49 times
2008ram1500hemi57_00.log
(62.67 KiB) Downloaded 53 times
there is some ST knock at the shifts. Thats not entirely uncommon when shifting. Can you log the stock tune as well in the same conditions?
