idle setting dont work well
frog19871230
Post by frog19871230 »
hi mikel:
My vehicle is chrysler 300 3.6L.i have set my idle setting with +400 both in D A/C off and in D A/C on.After fininshed flashing the tune,idle worked well in D A/C off,the ide works in 1150 r/min. But it not work in D A/C on,it worked in the factory idle setting (750 r/min). Here is my tune and info files. I think I have entered wrong paramater. Cloud you help me to set the correct paramater? thanks a lot!
Racing.drg
info.xml
Re: ide setting dont work well
load this tune and reset the parameter when it asks and let me know if it helps.
frog19871230
mikel wrote: Mon Nov 15, 2021 4:22 pm load this tune and reset the parameter when it asks and let me know if it helps.
thanks mikel!
I have flashed the tune you sent to me. But it not work ,either. There's another problem ,idle in P/N also works at 1150 r/min.
Re: idle setting dont work well
post the last tune written file from the device after you load the custom tune i sent.
frog19871230
mikel wrote: Thu Nov 18, 2021 10:04 am post the last tune written file from the device after you load the custom tune i sent.
there's tune. thanks !!!!!!
frog19871230
Happy Thanksgiving Day, mikel!
i have change some parameter base on the tune you sent me. the new tune have a good change! idle works correctly in D (both with ac on/off). but it dont well in N/P (both with ac on/off). no mater how i changed the setting of idle in N/P (both with ac on/off), idle in N/P always worked at 1500 r/min. now, i just want the idle in N/P worked at the stock setting.
there's the new tune i changed.
thanks again !
Racing_fans_change.drg
please clarify what you are asking for here?
