READING FUEL PRESSURE
This section of the forum is for discussion relating to the T2 tuner/monitor on Ford vehicles.
WildHorse
Post by WildHorse »
Is there a PID for reading the fuel pressure at the fuel rails ? Thanks.
Gʀᴀʙʙᴇʀ Bʟᴜᴇ 2017 Mᴜsᴛᴀɴɢ GT 300A
Re: READING FUEL PRESSURE
I am not sure if thats on the tool or not. I'll check, but it would probably be listed as FRP or similar.
tech@diablosport.com
WildHorse
Post by WildHorse »
The only thing I found under 'advance' was FPDC ( fuel pump duty cycle ). But it show weird numbers like from 1000 to 26747. No idea what that means. Tried changing it from 0-100% but it always reverts back to those odd numbers.
WildHorse wrote: Mon Mar 21, 2022 7:50 pm The only thing I found under 'advance' was FPDC ( fuel pump duty cycle ). But it show weird numbers like from 1000 to 26747. No idea what that means. Tried changing it from 0-100% but it always reverts back to those odd numbers.
do you have a copy of the log with the FPDC data?
WildHorse
Post by WildHorse »
mikel wrote: Wed Mar 23, 2022 4:55 pm
Should be on the last log I sent.
OK, I found one of the logs and the data is odd, let me see whats up with that.
WildHorse
Post by WildHorse »
mikel wrote: Tue Mar 29, 2022 9:44 am OK, I found one of the logs and the data is odd, let me see whats up with that.
Here is another log incase you need it.
21427_29.log
They are currently looking into that pid not displaying properly.
WildHorse
Post by WildHorse »
mikel wrote: Wed Apr 06, 2022 11:39 am They are currently looking into that pid not displaying properly.
Great ! Let us know when the fix is applied ! :D
