Gen 4 Ram 5.7 MDS deactivate
I have a 2014 Ram 1500 with the 5.7. My Diablo i3 had the MDS deactivation option which I left off. So the MDS will engage. I went to shut it off today and the option isn’t there. Any suggestions?
Re: Gen 4 Ram 5.7 MDS deactivate
are you looking under the modify parameter menu in the advanced tune section?
Yes, I also tried running an update, changing the installed tune and resetting everything. I can adjust tire size and turn off speed limit. I also remember there being a throttle response adjustment that is no longer there?
it still sounds like you may be in the easy tune menu?
It should definitely have a list of thing you can change including throttle boost in the modify tune menu.
I plugged it back in after doing an update last night and now is saying I need an update and the vehicle is not supported
its asking to update the device so it can get the files it needs to update the pcm or tcm in the truck.
I updated it then it said this. So I repeated it and it says there is an update, so I update it and it says the same thing.
