Help Duramax problem
Coming back from a trip to florida which i drove down stock...thought i would drive back in the 40 or 65 horse to see a diff. in gas milage..programmed the truck and nothing worked..speed was showing about 65 but i know i was at least 80...and both brake lights came on and the brakes wouldnt work right...abs and emergency brake dummy lights that is ....had to pull over and put it back to stock...now its fine... any bright ideas.....i have used the preditor for a while and the only real problem i have had was with it surging while driving ...which this problem has never been addressed...now this problem...which makes it impossible to drive..what do the experts think
RE: Help Duramax problem
What part number is this?
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
Is this a new problem, as in the unit worked in the truck previously?
Have you changed the wheel/tire size?
If so, did you change the settings in the Predator?
U7186 06 LLY
the dealer installed a new cluster...it has worked before but had some surging at some speeds...if they reflashed it why would my brakes and lights ack up and speedometer not work...It is a U7186,,,2006 duramax LLY
RE: U7186 06 LLY
Can you please post the revision on this tool.
We addressed an issue in the 1r17 revision where changing the tire size would cause those issues.
Please update to the latest revision to cure this problem.
