T2 for 2010 str8 Challenger raised shift points
I just upgraded from the Intune programmer to the T2 for my 6.1L The tune in the T2 has my car shifting at 5500 RPM and the INtune was 6200 RPM. Am I doing something wrong? I choose the raised SHift points and I raised my rev limiter. I just ran my car down the track and I have lost 5mp in my quarter mile also. Can I manually raise up the shift points on these?
Re: T2 for 2010 str8 Challenger raised shift points
double check that you selected and saved the raised shift point option under quick adjust please.
Yes it is definitely selected. When I raced my car shifted at 5500 from 1st to second.
ok, just trying to veryfy things, have you gone back and reselected it?
or tried going back to default to make sure it does what it should there?
Yes I tried to re do it and I also tried a different tune to see if it helps. I have a CAI so I first tried the 91 octane tune and CAI and this time I did the diablo tune. But it still shifts fairly early. I raised my shift points and I raised my Rev limiter.
if you reselect stock shift points do they go back to where they should be?
