Hello (old member here, I just can't remember my password and don't have access to my old email linked to my account on this forum anymore).
I have a nice tune that Mikel did to me a while back for my 11' SS. So far so good, I've never changed it since I flashed it. The Only thing that was done to the car was removing the cats and replaced them with BBK (about to put back the OEM cats though cause EU aren't fan of loud cars )
As I explained on the Ford thread, my situation has recently changed and I'm moving to the EU ( with plenty of E85 at every corner and much cheaper than regular/premium gas ).
Could it be possible to get an E85 tune on my i2 without changing/adding anything on to the car ?
(Also, I'll post on the other sub-forum but I have an 16' Stang that runs great with the 93 tune for years. I was wondering if I could do the same and pass it on E85 ?)
Thanks!
i2 - E85 Tune - 2011 Camaro 2SS BVA
Re: i2 - E85 Tune - 2011 Camaro 2SS BVA
No... there are no e85/flex fuel settings available at all in the tune file for that car, since it is not a factory flex-fuel vehicle...
Also since it is not a factory flex fuel vehicle, you'd need to add a flex fuel sensor, bigger injectors, and bigger, higher-flowing fuel pump... because e85 requires more fuel, it requires larger fuel injectors and a higher flowing pump to use E85. Because more fuel is being used to achieve the same effect as normal gasoline... E85 does not atomize and ignite as easily as normal gas, so it requires about 30% more fuel/fuel flow than regular gas to achieve the same power.
Hes not asking about flex06MonteSS wrote: ↑Fri Sep 23, 2022 11:21 am No... there are no e85/flex fuel settings available at all in the tune file for that car, since it is not a factory flex-fuel vehicle...
tech@diablosport.com
I dont know if the factory fuel system has enough volume to support E at stock LS3 power levels, but if so, you could certainly have a tune made to work with e85. I'm not 100% sure if the injectors have enough headroom either.Taco-Giz wrote: ↑Fri Sep 23, 2022 5:30 am Hello (old member here, I just can't remember my password and don't have access to my old email linked to my account on this forum anymore).
Thanks!
well, either way... would need bigger injectors, bigger higher-flowing fuel pump... and once it's tuned for e85, he would have to use e85 all the time, or would have to have a separate tune for normal 95/95 octane, since the ECM has no flex-fuel capability...mikel wrote: ↑Fri Sep 23, 2022 1:07 pmHes not asking about flex06MonteSS wrote: ↑Fri Sep 23, 2022 11:21 am No... there are no e85/flex fuel settings available at all in the tune file for that car, since it is not a factory flex-fuel vehicle...
Yes, I'll be using E85 every time without going back to regular/premium gas. They have E85 almost on every gas station and it's much cheaper than regular gas.
E85 goes around: 0.40-0.70 cts / Liter
98 gas (equivalent to 93 US gas): 1.60-1.80 / Liter
Right now the car has a 93 tune and I feel that it runs better when I use 98 EU gas than when I used 93 US gas. Not sure if it's placebo effect or not tho lol
Yeah, good luck with that....
