rough idle then dies w/ intune.
Hello,
I have a 2014 Chrysler 300s 5.7 that I have tried to upload a tune into three times in a row I end up with rough idle then the engine dies, I reinstall the stock tune and the motor runs just fine. I cant seem to find a "patch" for my 300. its almost like the tuner is loading a non VVT tune into the pcm. Any help/input would be greatly appreciated! also ive updated my intune twice.
Thank you!
Thank you!
Re: rough idle then dies w/ intune.
are you making any adjustments to the tune when you install it?
Rev limit in neutral specifically?
I'm currently having the same issue (2013 300s 5.7 liter). What did you end up doing to correct the problem?
are you adjusting the rev limit in neutral when you load the tune??
No, I'm not adjusting anything. I tried the easy tune and advanced. The only thing I adjust in advanced is MDS off and increase throttle sensitivity to 10.
please load the tune then post the last tune written from the tunes folder on the i3 drive here before returning to stock.
does it idle rough in P/N and D, or just in D?
There are no tunes in the tunes folder but they do come up in the i3 when I choose a tune. I included the two log files. With the 93 octane "DiabloTune" the car runs rough and idles for approximately 30 seconds then shuts off in P. Doesn't run long enough to move the vehicle. 2013 Chrysler 300S 5.7 liter Hemi
https://drive.google.com/file/d/1RW_toW ... p=drivesdk
I tried to include the log files but I'm unable to upload attachments.
you have to load the tune to the car then the tunes will be in the folder.
Okay, I just can't get it right. The "tune" folder is empty. There was a folder with my VIN number and a tune once upon a time but now it's gone. Guess the tune is erased once I revert back to the backup tune. I had to revert back to the backup tune so the vehicle would run. I understand now, I have to have one of the canned tunes installed to be able to pull a tune from the i3. I still can't upload an attachment to this thread.
not sure whats up with the attachments. email it to me with a link to this thread, mlitsch @ diablosport.com
Thank You, sent.
hmmm....I haven't received anything?
try michaellitsch @ holley.com
Forwarded the original. Hopefully you can still access the attachments. Let me know when you get a chance.
pretty sure I see what the issue is, trying to determine whats causing it
