i3 cant find fan settings
Had my i3 for awhile with some custom tunes installed. Recently had to restore to stock/backup file to diagnose a driveability problem which turned out to be a blown fuel pump fuse. With the stock tune the ECT is running hotter than ever before. I do not want to reload the custom tune since I am bringing the car back to stock. I am running a 180- Tstat and would like to simply adjust the fan settings. When I go to "quick adjust" I only see transmission, tire size and traction control. Where do I look for the fan settings?
Re: i3 cant find fan settings
you need to go through the advanced menu and select modify parameters
