2022 PCM
Re: 2022 PCM
no, the swap is a one time deal. you can send your original pcm for a $200 unlock if you wish.
Re: 2022 PCM
Quick question, Mike.
Taking the truck in for a recall that requires a software update. Do I simply need to swap out the tuned PCM and put the factory PCM back in or do I need to remove the bypass module as well?
I shouldn't need to remove any tuning etc correct?
2022 Ram Limited Hemi eTorque - Brilliant Black Crystal Pearl
Borla S-Type Catback Exhaust
Re: 2022 PCM
bypass module needs to be removed for any dealer visit, or they wont be able to communicate with the truck.
Re: 2022 PCM
Thank you!
