REAR DIFFERENTIAL OPTIONS?
T91WHEELER
Post by T91WHEELER »
I noticed in my Predator last night, that the newest version seems to support different rear differential ratios than the stock 2.82:1. Is this correct? Anyone know who is selling ring and pinions? Looking for about a 3.43:1. I remember seeing 3.07 as a option in Predator. I belive this is the same as the AWD. Can the AWD ring and pinion be used in a RWD?
Boggus
RE: REAR DIFFERENTIAL OPTIONS?
Post by Boggus »
CMJ on chargerforums.com or lxforums.com is putting together a group buy on 3.23 gears if they can get enough interest to sway the good folks that can make them.
fordomatic69
Post by fordomatic69 »
Fordomatic Says:
"I've heard of Vaporware... but I've never actually seen it" :lol:
http://www.twincamlubricants.com - For all your synthetic lubricant needs. Order Online and save over retail.
rodneyiii
Re: REAR DIFFERENTIAL OPTIONS?
Post by rodneyiii »
T91WHEELER wrote:I remember seeing 3.07 as a option in Predator. I belive this is the same as the AWD. Can the AWD ring and pinion be used in a RWD?
To answer your question - The AWD rear gears are smaller (198mm) than the RWD V8 gears (210mm and 215mm). The AWD housings are smaller since they are only designed to handle V6 power or half of the V8 power when split front and rear. Hope this helps.
2006 Charger SRT8
born on 6-21-06, home on 4-21-10.
fordomatic69
what is the source for your above statement "The AWD housings are smaller since they are only designed to handle V6 power or half of the V8 power when split front and rear." I searched for this info and could not find it.
Fordomatic Says:
RE: Re: REAR DIFFERENTIAL OPTIONS?
He's right. Its like that on the 4Matic Mercedes E-class too. The rear on the awd is 198mm ring gear, the rwd has a 215mm.
