smoke and fuel pressure Q's
ohyeahfriday
Post by ohyeahfriday »
Currently looking into the predator/puck stack, as well as a couple other programmer options. I like what I have read about your stuff/support.
First question is with the stack installed, will I be seeing some clouds in my rear view?
Secondly, I think I have read it before, but have to ask anyway, on the 2004.5 Ram 2500, will this stack be "safe" in regards to fuel pressures? I was not looking to upgrade the fuel system at this time, so I want to be on the safe side.
Pat
johan
RE: smoke and fuel pressure Q
Post by johan »
Depending on what tune you will be running, the extreme tune will puff smoke as you romp on it but will clear up if you stay in it. The other tunes will smoke a lot less.
We ensured that the stock fuel system supports the extreme stack combo, no need to upgrade as long as you run stock boost.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
reb0957
Post by reb0957 »
PAT
Anytime you stomp you will get a puff with the Predator! Even on tow! I have a 6 speed so that maybe the difference. I installed the towstack tune last night and wanted to feel it out before I switched the puck on. The towstack tune by itself still puffs some smoke but nothing like the plain performance tune or extreme tune. The extreme tune can cloud a WHOLE intersection with a little manipulation on my part!
On a different note a pyrometer is definately necessary on anything more than tow. I can hit 1500 degrees before I am pulling out of 4th gear on the performance or extreme tune with an empty truck! I have never tried the extreme stack tune since I just installed the puck last night!
Herculou
Post by Herculou »
reb0957,
I have a 6 speed as well. I was a bit worried that the Extream tune would damage the clutch. Have you had any issues?
Lou
06 CTD, AFE, 6 speed 3.73, predator
reb0957
Re: RE: smoke and fuel pressure Q
Post by reb0957 »
Herculou wrote:reb0957,
Lou
Extreme TUne is a clutch killer if you are going to play with it!
If I would stomp it in 6th at 60mph my RPM's would rise and then I would take off like a scalded ape! I first thought that RPM increase was the tires spinning but that original RPM spike was not accompanied by a change in SPeed! So, it was definately the CLUTCH! But If i would drive sanely and not STOMP the go pedal lto the floor it was OK! AGAIN need a pyrometer!
Herculou
RE: Re: RE: smoke and fuel pressure Q
Post by Herculou »
I had to have the pressure plate replaced @ 4500 miles on the truck (bad from factory) & I heard the clutch was the weak link in the dodge. So, this is really good info to have Thanks!
reb0957
Post by reb0957 »
HERCULOU
Don't let this scare you! Their products are great! If you only KNEW how long I waited to get mine in!
And the customer service here is 100x better than the product!
ohyeahfriday
Yeah, I am running a 6 speed NV5600 as well. I have to admit so far, this seems like a pretty good option for an "entry level" stack.
Thanks for the quick responses :D
modified03
Post by modified03 »
I run the extreme stacker tune all the time and can get up to 1500 degrees and 0 on fuel pressure pretty easy. will running it on extreme stacker eventually wear my tranny down if i drive it sensibly.
fyrguy316
Re: RE: Re: RE: smoke and fuel pressure Q
Post by fyrguy316 »
reb0957 wrote:HERCULOU
this absolutely correct. the predator/ puck stack is a great combo. i love mine, but i would highly reccomend a pyrometer and boost gauge especially if your going to tow with it. i tow a gooseneck flat bed and even with the straight tow tune my EGT's were higher than i liked them to be. now keep in mind this is mostly if your towing. if your just driving its not quite as vital, but in my opinion if your going to put any aftermarket performance box on your truck, get gauges. you need to know what that motor is doing. if you see high EGT's and want to keep them under control buy a boost fooler. i did and it helped tremendously. good luck.
05 2500 SLT, 600 cummins, 6 SPD, Predator/Puck Stack, Quad. Boost Fooler, ISSPRO Pyro and Boost, ISSPRO Turbo Temp Monitor, MBRP Exhaust, AFE Stg 2 PG 7, REESE rail setup for 5th wheel or The Goose, PJ Gooseneck 25 ft 14,000 GVW
johan
RE: Re: RE: Re: RE: smoke and fuel pressure Q
Post by johan »
I agree with fyrguy, $500 for a good egt/boost gauge setup is a cheap insurance considering the alternative.
Diablosport INC
