Ok so i have read about a few problems similar to mine but not exactly the same. When logging in DV on my laptop, Analog 2 is selectable and can see it moving while logging. Its in VDC but its there. After the run and saving the log, the Analog 2 input is not visible during the playback. Its not even there to select. BUT!! If i log with the handheld unit without the laptop hooked up Analog 2 records and is visible on playback in DV. Am i possibly missing something here? Did i not set somthing up rite? Is there an update needed to fix this? any help would be great!
03PTGT auto
I3
Inovate DB gauge w/LC2
Analog/WB input not showing up on playback in DV
Re: Analog/WB input not showing up on playback in DV
Have you by chance tried DV2?
Connect your device to your PC and run the Update Agent program to make sure your device is up to date. There were issues in the past with streaming from the device through DataViewer that have been fixed. If Update Agent has issues, try again tomorrow. I've heard they were having technical issues on the update server today.
DV2 does not currently support streaming of analogs from i3, but that feature is in work and coming very soon!
Update Agent can be downloaded here: https://www.holley.com/support/tuners/diablosport/
Thanks guys!! I'll definitely give it a shot.
Welp, everything is updated and still no Analog input showing while recording with the DV on the laptop. Still shows up at first as a selectable PID but disappears when I start to record.
OK, there is a fix for DV2 to support this coming soon.
OK cool. Fingers crossed
Open DV2 and it should update and work now.
Sweet. I'll give it a try and let you know.
