Question on 7201
Discuss Predator 2 for GM vehicles.
sirdano
Question on 7201
Post by sirdano »
Does it have throttle booster
Will it turn off torque management in transmission
Is there a set/can tune for transmission
Oh this will be installed on 2009 corvette 6.2l a6
Thanks for all replys
Re: Question on 7201
No, there is no throttle boost setting for that car... That setting/adjustment is only available on 2014 or newer vehicles, as they have a different ECM/programming...
You can choose to modify the preset canned tune and disable the tranny torque management setting...
Yes there's a preset canned tranny tune...
sirdano
Post by sirdano »
Thanks for the quick response
if you can't see or find the torque management setting when you try to Modify the TCM/tranny tune, then that means it is already disabled in the preset canned TCM/tranny tune you're going to install.. so there's no setting to disable via the tool..
