I'm looking for any information as to how I can remove the throttle delay in any tune on the Predator U7140(preferably the performance 93 octane tune). I have the calid, serial numbers, etc..., if needed. Any help would be greatly appreciated. Version v.8r38. Thanks.
Scott
U7140 - 2005 GT - Throttle Delay
RE: U7140 - 2005 GT - Throttle Delay
Hmmm,,,delay should be gone in a tune, can you describe the issue some more?
LoneSailor
Push the pedal down to accelerate and there is still a delay. It's not quite as pronounced as the stock tune, but still noticeable, and annoying. I know the converter will allow a slight lag like feel, and honestly that doesn't feel like what's going on. My other car has a mild 3000 stall converter and they both pick up acceleration at about the same time. I could see the logic if Ford put in a 3000-3500 converter in these cars, but that would never happen in the real world.
Maybe I'm expecting too much with wanting the throttle response to be immediate?
calid: FBHR2G4HEX
serial:2000c52
calid: FBHR2G4HEX
serial:2000c52
TonysOrangeCapri
Scott, Your 05 with the "fly by wire" probably wont ever have the same feel as your Foxbody with a manual throttle cable. I would imagine there will always be some slight lag. The diablosport should take car of some of the lag, but I doubt it will ever feel as good as a manual throttle cable. Im sure Mikel will have more imput on this topic as well. Later Man, ~Tony~
01 Cobra DOHC 5.4
39lb hr injectors
Suliivan Intake Manifold
39lb hr injectors
Yeah, i have seen some tuners get aggresive with throttle response, give a call to Doug at babachips and ask about a custom tune for better throttle response, he should be able to make it get up and go how you'd like.
LoneSailor
Thanks guys.
