Shift kit
RE: Shift kit
nope, since you can't adjust any tranny settings with the predator anyway...
RE: Shift kit
O.K. I thought when I can change my T.M. settings, change how fast my shifts are, what RPM's my shifts are. how firm my shifts are I am not actually adjusting my trans settings? I have the U7192
RE: Shift kit
Yeah, you can do all of that with your Predator if you like...
RE: Shift kit
WHAT?? he can do all that with HIS 06 vehicle???!!!!
RE: Shift kit
Yea I have done it all but do I need to change anything that the came standard with my programer. Basically I have adjusted what the programer has changed so do I need to change anything the programer or any thing I have changed to keep anything from screwing up my trans.
Re: RE: Shift kit
Lol, classic trucks still use class II PCMs, no CAN till NBS 07....haha06MonteSS wrote:WHAT?? he can do all that with HIS 06 vehicle???!!!!
Re: RE: Shift kit
Tranny settings are up to the individual user, feel free to experiment a bit with shift pressures, likely no gain by raising shift points on a stock truck.SLEEPERSS wrote:Yea I have done it all but do I need to change anything that the came standard with my programer. Basically I have adjusted what the programer has changed so do I need to change anything the programer or any thing I have changed to keep anything from screwing up my trans.
RE: Re: RE: Shift kit
So when I have the shift kit installed everyrhing will be O.K. ? I will still get the classic shift kit performance and the truck computer will not affect the shift kit.
We do make a slight shift firmness change in the tune, so if it is too hard with the tune, try backing down the firmness a bit...
Sounds good. I did adjust the pressure was closer to what I wanted but still want that good old fashion 2nd gear chirp you get from a shift kit.
While I have your attention Mikel if I change the cam in my truck is my preditor able to handle my cam change or do I need a custom tune.
Custom tune for sure...
Can I custom tune my preditor for the cam change?
Yeah you can.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
