U7191 fan settings/TM question
WrlyBrd
Post by WrlyBrd »
Hi guys,
I have on 05 GTO 6spd, Predator U7191 version 7.R92. I have not made any parameter changes other than CAGS off. My 1st question concerns the frequency of my fan cycling off and on. After the car has warmed up, the fans consistantly cycle off and on for only seconds at a time and when turned on, stay on between a fraction of a second to just a few seconds then back off for a matter of seconds, then on again. Doesn't stay on long enough to be of any benefit. I didn't have this happen with my 02 Z06 w/Predator tune, so I'm wondering if it's simply a matter of making an adjustment as far as the fan setting?
Second question is in regards to torque management settings. I have no window within parameter modifications to make TM adjustments. There is nothing in regards to TM anywhere. I'm hoping this is due to my version being older and will an update make TM settings available?
Any info greatly appreciated,
Bob
johan
RE: U7191 fan settings/TM question
Post by johan »
I would recommend updating the predator, you will get more precise fan adjustments and there was a fix for the issue you are explaining as well. The TM is disabled in the Diablo tunes by default. There are no adjustments for that in the new update either.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Return to “Predator GM Gas”
