view 2 or more logs at the same time so you can compare them
Please give us suggestions on how to serve you better!
tomssrt8
Post by tomssrt8 »
I would like to be able to compare 2 or more data logs at the same time in one windo.
johnc
RE: view 2 or more logs at the same time so you can compare
Post by johnc »
That is a good suggestion.
johnc <at> diablosport.com
Hmmm, wouldn't this be a little easier to do in excel?
You could see anything you want side by side....
yeah, exactly!! ^^^^^
tomssrt8
Post by tomssrt8 »
Like they say, a picture is worth a thousand words (or numbers).
Having the ability to see both runs at the same time is a lot more beneficial than looking at a spreadsheet full of numbers.
johnc
Post by johnc »
Unfortunately this would be a major re-write, and would be better left until the next major revision.
tommyd
Post by tommyd »
Well I decided to create a virtual pc using vmware server and now have 2 dataviewers running at the same time. One on the actual PC and one in the virtual pc.
Now I can look at 2 logs at the same time. This is a workaround but I think Diablo should really include this option in the next software realease of the Dataviewer program
Return to “Suggestion Box”
