MDS WONT TURN OFF
MDS WONT TURN OFF
We have a 2005 magnum with the 5.7 hemi i have went in to MDS and shut it off and every time i go back in to it the MDS is on this car is not for the street we have turned it in to a mega truck and we don't want the MDS on is there some thing i need to change before turning the MDS off thank you
Re: MDS WONT TURN OFF
I am experiencing the same problem, so I am interested to see a solution.
if you turn it off then load the tune, its off. if you go back and look it will default to the ON selection but its not ON unless you select that, save the change then load the tune with it ON.
I will give it a try thank you have a blessed evening
When I make a change to another setting such as mph limit and then go into the tune later, that mph limit setting stays, but the mds will go back to in the on position. Because of this inconsistency it made me think it wasn't saving.
its a tricky deal with how some parameters are set up.
It can be misleading, but we're glad to help when needed
