Okay il start from the beginning, I had ordered a diablosport tuner in December of 2022 I was looking for a little bit extra so I ended up going with a Hemifever custom tune. And I'm loving the tune so far the only issue is the fan settings do not adjust with my changes. For example the Diablo tune will kick the fans on at 204゚ Fahrenheit though the desired ETC is set to 221 Fahrenheit. I've spoken with Sean from hemifever on the issue and everything with the tune seems to be operating properly I have swapped the thermostat to a 190゚ thermostats so I'm looking to set the fans to kick on at 205 and kick off at 192 Fahrenheit.
I've tried everything under the sun, updating the unit, adjusting desired ect to 160°, updated tunes from Sean, reloading the tune 10 times to no avail. I'm sure it's a diablosport issue because the Diablo 93 tune kicks the fan on at a lower temp but even though the tuner says 221.
I've been back and fourth on this for days now and haven't had any help from the support team over the phone.
I'd love to just have my custom tune with just the fan settings from the diablo tune
..someone please help I'm pleading over here
2018 Ram 1500 5.7 Custom Tune Fan Settings HUGE ISSUES
Re: 2018 Ram 1500 5.7 Custom Tune Fan Settings HUGE ISSUES
so hemifever has sent you tunes with the fans adjusted and it still doesn't work?
Something isn't adding up.
Attachments arent working, so I am going to ask you to email me some files....
1. Send me one of the tunes Sean sent you
2. Send me a last tune written from the device after you load the diablo tune with the fan settings adjusted
3. Send me the last tune written of the diablo tune when you have made NO changes to it.
mlitsch @ powerteq.com
tech@diablosport.com
Okay Mike that sounds good. Il do that as soon as I can
