PC COM Problem
jcbst12
PC COM Problem
Post by jcbst12 »
Tried Uploading a Tune to my PC at work. Used standard serial cable and appropriate power adapter. Set to COM 1, baurate of 57600. No communication. Tried COM 2 setup, same thing. Any ideas?
Thanks!~
99' Silverado 5.3L 4X4
- 4" Cold Air Intake
- Throttle Body Spacer
- 180 Powerstat
- Predator Programmed 93 (Modified)
- Clear Corners
- 17" GMC 6-Spoke Rims
- Alpine and MTX System
BJL630
Post by BJL630 »
I may be wrong as I don't have mine with me to connect & verify, but I think the baud rate should be 115,200.
2017 Dodge Charger Daytona 392
jcbst12
Post by jcbst12 »
Tried it nothing. Any other ideas, baudrates?
- 180 Powerstat
- Clear Corners
BJL630
Post by BJL630 »
Are you using the E40 PC interface software? If not, it can be downloaded from this site.
jcbst12
Post by jcbst12 »
Yep, lol, it so frustrating the only thing I can thing of is a problem with the cable or baudrate
- 180 Powerstat
- Clear Corners
Actually should be using 99-02 PC interface, not E40...
jcbst12
Post by jcbst12 »
Oh yeah, well let me correct myself, I am using the correct interface as I threw the one I used at home on a disk and brought it to work with me.
- 180 Powerstat
- Clear Corners
OK, if it is not a straight through type serial cable, it will not work.
Also, you should be able to see what com port it is on in the device manager.
Baud rate should be set to 57600.
If you continue to have issues, i would suggest a USB to serial cable.
