I recently purchased an i3 tuner for my 2022 Mustang GT and the power increase is very good on 93 oct.
I noticed the for the 2021s, adjustable parameters are available, but not on my 2022. Will there be an update soon to make them available
for 2022s as well? Thanks.
2022 Mustang GT Adjustable Parameters
Re: 2022 Mustang GT Adjustable Parameters
you should have all the same parameters as any 18+ 5.0 A10.
What do you see in the menu when you select the modify parameter option in advanced tune?
I only saw an option for top speed limit. I thought I would see shift points, tire size, etc. I will check it again.
make sure you are in the advanced menu under 'modify parameters' and not in the easy tune menu
Will do. Thanks!
