2022 Mustang GT Adjustable Parameters
Wadec
Post by Wadec »
I recently purchased an i3 tuner for my 2022 Mustang GT and the power increase is very good on 93 oct.
I noticed the for the 2021s, adjustable parameters are available, but not on my 2022. Will there be an update soon to make them available
for 2022s as well? Thanks.
Re: 2022 Mustang GT Adjustable Parameters
you should have all the same parameters as any 18+ 5.0 A10.
What do you see in the menu when you select the modify parameter option in advanced tune?
Wadec
Post by Wadec »
I only saw an option for top speed limit. I thought I would see shift points, tire size, etc. I will check it again.
make sure you are in the advanced menu under 'modify parameters' and not in the easy tune menu ;)
Wadec
Post by Wadec »
Will do. Thanks!
